Saltar al contenido principal
Removing the Apple Cinema Display M8149 Display Hinge
Qué necesitas
  1. Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: paso 1, imagen 1 de 3 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: paso 1, imagen 2 de 3 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: paso 1, imagen 3 de 3
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
  2. Removing the Apple Cinema Display M8149 Display Hinge: paso 2, imagen 1 de 3 Removing the Apple Cinema Display M8149 Display Hinge: paso 2, imagen 2 de 3 Removing the Apple Cinema Display M8149 Display Hinge: paso 2, imagen 3 de 3
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. Removing the Apple Cinema Display M8149 Display Hinge: paso 3, imagen 1 de 2 Removing the Apple Cinema Display M8149 Display Hinge: paso 3, imagen 2 de 2
    • Remove the Apple Display Connector plate screws (9.52 x 3.43 mm) with the PH 2 screwdriver.
    • Once the two screws have been removed, move the cord out of the way.
  4. Removing the Apple Cinema Display M8149 Display Hinge: paso 4, imagen 1 de 3 Removing the Apple Cinema Display M8149 Display Hinge: paso 4, imagen 2 de 3 Removing the Apple Cinema Display M8149 Display Hinge: paso 4, imagen 3 de 3
    • Remove the hinge plate screws (5.52 x 3.43 mm) with the PH 2 screw driver.
    • Then lift out the hinge mount.
Conclusión
3 personas más completaron esta guía.
Thomas Harper
Miembro Desde 04/01/11
244 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-41, Forte Spring 2011 Miembro de Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Miembros
12 Guías creadas
Un comentario
in 2023 where can I get a replacement stand?
Mitch Leung - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 7,790
