Partes
No se requieren partes.
Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove flip  the cover.
  • Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove flip the cover.
Agregar Comentario
Remove the cover with  a slight twisting motion. This is what the phone will look like after the cover is removed.
  • Remove the cover with a slight twisting motion. This is what the phone will look like after the cover is removed.
Agregar Comentario
To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base. To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base.
  • To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
manning
Miembro Desde 12/03/12
21 Reputación
2 Guías creadas
Equipo
Clemson, Team 1-4, Benson Spring 2012 Miembro de Clemson, Team 1-4, Benson Spring 2012
CLEM-BENSON-S12S1G4
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 6
Todo El Tiempo: 1,608
