Introducción
Before removing the Motherboard you must first remove the LCD Screen.
The battery compartment is located on the bottom side of the camera.  Push the button in, and slide the cover to get access to the batteries. The battery compartment is located on the bottom side of the camera.  Push the button in, and slide the cover to get access to the batteries.
  • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
Agregar Comentario
The batteries will slide right out. When putting new batteries in, make sure they are pointing the right direction.
  • The batteries will slide right out.
  • When putting new batteries in, make sure they are pointing the right direction.
Agregar Comentario
Remove the 7 screws holding the front case in place, with a #00 screwdriver. Six screws are 3.6 mm. The seventh screw is 3.2 mm.
  • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
Agregar Comentario
Pulling the front case off, requires applying enough strength in the right areas. The front case snaps into place in three places: At the top and bottom of the battery side (opposite of side pictured) of the case.
  • Pulling the front case off, requires applying enough strength in the right areas.
  • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
  • Once those places are disconnected, the front case will pop right off.
  • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
Agregar Comentario
Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
  • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
  • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard. Lift the white latch using a fingernail or a spudger. Pull the cord from its connector.
  • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
  • Lift the white latch using a fingernail or a spudger.
  • Pull the cord from its connector.
Agregar Comentario
Remove the two 2.7 mm screws using a #00 screwdriver. After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
  • Remove the two 2.7 mm screws using a #00 screwdriver.
  • After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
Agregar Comentario
Using a spudger, lift the latch on the connector. Remove the ribbon cord from its connector. Remove the LCD from the rest of the camera.
  • Using a spudger, lift the latch on the connector.
  • Remove the ribbon cord from its connector.
  • Remove the LCD from the rest of the camera.
Agregar Comentario
Remove the 2 pieces of translucent yellow tape. Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
  • Remove the 2 pieces of translucent yellow tape.
  • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
Agregar Comentario
Remove the seven 2.7 mm using a #00 screwdriver. Remove the seven 2.7 mm using a #00 screwdriver.
  • Remove the seven 2.7 mm using a #00 screwdriver.
Agregar Comentario
Remove the ribbon cord located near the top right corner of the motherboard.  Do this by carefully pulling the cord out of the socket using a pair of tweezers.
  • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
Agregar Comentario
Disconnect the ribbon cord located on the left side of the motherboard.
  • Disconnect the ribbon cord located on the left side of the motherboard.
  • Use tweezers or a spudger to lift the latch on the connector.
  • Carefully remove the cord from the connector.
Agregar Comentario
De-solder the 2 connection points. Be careful to not damage any part of the circuit board with the soldering iron.
  • De-solder the 2 connection points.
  • Be careful to not damage any part of the circuit board with the soldering iron.
Agregar Comentario
Remove the motherboard from the camera casing.
  • Remove the motherboard from the camera casing.
Agregar Comentario
Conclusión
Alex Wolff
Miembro Desde 21/01/11
234 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 4-36, Regan Winter 2011 Miembro de Cal Poly, Team 4-36, Regan Winter 2011
CPSU-REGAN-W11S4G36
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 11
Todo El Tiempo: 3,217
