Saltar al contenido principal
Nokia 3100b Screen Replacement
Qué necesitas
  1. Nokia 3100b Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure your phone is turned off.
  2. Nokia 3100b Screen Replacement: paso 2, imagen 1 de 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Nokia 3100b Screen Replacement, SIM Card: paso 3, imagen 1 de 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Nokia 3100b Screen Replacement: paso 4, imagen 1 de 1
    • Retrieve your SIM card.
  5. Nokia 3100b Screen Replacement, Screen: paso 5, imagen 1 de 1
    • Separate the front cover from the main body of the phone.
  6. Nokia 3100b Screen Replacement: paso 6, imagen 1 de 1
    • Remove the six screws along the edges of the phone.
  7. Nokia 3100b Screen Replacement: paso 7, imagen 1 de 1
    • Pull the screen assembly from the base of the phone.
  8. Nokia 3100b Screen Replacement: paso 8, imagen 1 de 1
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Nokia 3100b Screen Replacement: paso 9, imagen 1 de 1
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Nokia 3100b Screen Replacement: paso 10, imagen 1 de 1
    • Gently push down on the screen to pop it off of the assembly.
  11. Nokia 3100b Screen Replacement: paso 11, imagen 1 de 1
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 29-64, Johann Spring 2010 Miembro de Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,763
