Introducción
Step-by-step guide to removing your phone's back plate.
Partes
No se requieren partes.
Flip phone to see back cover. Using either finger or spugder tool press button located  near the top of phone by the antenna.
  • Flip phone to see back cover.
  • Using either finger or spugder tool press button located near the top of phone by the antenna.
Agregar Comentario
Pry up back plate from phone to reveal battery. Push button near bottom of battery using either your finger of the spudger.  This will release the battery.
  • Pry up back plate from phone to reveal battery.
  • Push button near bottom of battery using either your finger of the spudger. This will release the battery.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
  • Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
Agregar Comentario
Simultaneously press indicated buttons on both sides of phone. Simultaneously press indicated buttons on both sides of phone.
  • Simultaneously press indicated buttons on both sides of phone.
Agregar Comentario
Separate back plate from the rest of phone.
  • Separate back plate from the rest of phone.
  • Make sure to not pull, there is a wire (circled on image) connecting the two plates.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 30-40, Garner Spring 2010 Miembro de Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 7
Todo El Tiempo: 3,139
