Saltar al contenido principal
Removing Canon PowerShot A550 Front and Back Covers
Qué necesitas
  1. Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: paso 1, imagen 1 de 3 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: paso 1, imagen 2 de 3 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: paso 1, imagen 3 de 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Removing Canon PowerShot A550 Front and Back Covers: paso 2, imagen 1 de 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Removing Canon PowerShot A550 Front and Back Covers: paso 3, imagen 1 de 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Removing Canon PowerShot A550 Front and Back Covers: paso 4, imagen 1 de 2 Removing Canon PowerShot A550 Front and Back Covers: paso 4, imagen 2 de 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Removing Canon PowerShot A550 Front and Back Covers: paso 5, imagen 1 de 1
    • The camera should look like this once the front cover is removed.
  6. Removing Canon PowerShot A550 Front and Back Covers: paso 6, imagen 1 de 3 Removing Canon PowerShot A550 Front and Back Covers: paso 6, imagen 2 de 3 Removing Canon PowerShot A550 Front and Back Covers: paso 6, imagen 3 de 3
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Removing Canon PowerShot A550 Front and Back Covers: paso 7, imagen 1 de 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
Conclusión
3 personas más completaron esta guía.
Shaelyn Thomas
Miembro Desde 04/19/11
332 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 8-6, Regan Spring 2011 Miembro de Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 27
Todo El Tiempo: 4,249
