Introducción
This guide will show how to remove the back cover.
Partes
No se requieren partes.
Remove the six external screws from the camera using a Phillips #0 screwdriver. After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera. Be careful, make sure you don't lose the screws.
  • Remove the six external screws from the camera using a Phillips #0 screwdriver.
  • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
  • Be careful, make sure you don't lose the screws.
Agregar Comentario
Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery. Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
Agregar Comentario
Carefully squeeze the top right corner of the camera and pry off the external cover.
  • Carefully squeeze the top right corner of the camera and pry off the external cover.
  • If you hear a "cracking" sound. This is normal.
  • Continue to pull the external cover and it will come off cleanly.
  • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
Agregar Comentario
Carefully pull off the back cover, parts behind the back of the case might fall out.
  • Carefully pull off the back cover, parts behind the back of the case might fall out.
Agregar Comentario
Linea de Meta
2 personas más completaron esta guía.
Hasit
Miembro Desde 15/04/10
168 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 6-17, Maness Spring 2010 Miembro de Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 3,301
