Saltar al contenido principal
Removal/Replacement of Dell Inspiron E1705 Hard Drive
Qué necesitas
  1. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Battery: paso 1, imagen 1 de 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Removal/Replacement of Dell Inspiron E1705 Hard Drive: paso 2, imagen 1 de 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive: paso 2, imagen 2 de 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: paso 3, imagen 1 de 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: paso 3, imagen 2 de 2
    • Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
    • These screws hold the hard drive tray into the hard drive compartment.
  4. Removal/Replacement of Dell Inspiron E1705 Hard Drive: paso 4, imagen 1 de 1
    • Slide the hard drive tray out of the hard drive compartment.
Conclusión
3 personas más completaron esta guía.
Malik Shahbal
Miembro Desde 10/05/10
471 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 22-5, Maness Fall 2010 Miembro de Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 20,259
