Saltar al contenido principal
Remington MB4040 Cover Assembly Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: paso 1, imagen 1 de 3 Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: paso 1, imagen 2 de 3 Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: paso 1, imagen 3 de 3
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Cover Assembly Replacement, Remove Back Cover Hardware: paso 2, imagen 1 de 2 Remington MB4040 Cover Assembly Replacement, Remove Back Cover Hardware: paso 2, imagen 2 de 2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: paso 3, imagen 1 de 3 Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: paso 3, imagen 2 de 3 Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: paso 3, imagen 3 de 3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Cover Assembly Replacement, Front Cover (cont.): paso 4, imagen 1 de 2 Remington MB4040 Cover Assembly Replacement, Front Cover (cont.): paso 4, imagen 2 de 2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Cover Assembly Replacement, Blade Button Removal: paso 5, imagen 1 de 2 Remington MB4040 Cover Assembly Replacement, Blade Button Removal: paso 5, imagen 2 de 2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
Conclusión
Cameron Carnahan
Miembro Desde 01/20/15
1,067 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 1-5, Blackwell Winter 2015 Miembro de USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 87
