Saltar al contenido principal
Razer Ouroboros Battery Replacement
Qué necesitas
  1. Razer Ouroboros Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Begin by turning the mouse upside down.
    • Use a Phillips #00 to loosen the two captive screws circled in the first image.
    • These screws do NOT come out, they merely loosen.
    • Slide the palm rest toward the back of the mouse. It should slide down its track and come right off.
  2. Razer Ouroboros Battery Replacement: paso 2, imagen 1 de 1
    • This is the bottom of the palm rest.
    • Turn the knob highlighted by the red circle will change the height of the palm rest for maximum comfort.
  3. Razer Ouroboros Battery Replacement: paso 3, imagen 1 de 1
    • The battery compartment is on the back side and is easily viewed once the palm rest is removed. Simply push up gently and the hinged battery door opens from the bottom
    • Place the new battery into circular slot shown in the picture. The battery should be placed in positive side first.
    • You must use rechargeable batteries in this mouse.
Conclusión
7 personas más completaron esta guía.
Brandon Jones
Miembro Desde 07/19/16
308 Reputación
1 Guía escrita
Equipo
8 comentarios
is the battery a standard AA battery size or did they use a different size?
adiforipod - Contestar
Standard AA size mate
Minty Fox - Contestar
… what happens if I don't use a rechargeable battery?
Russell Phillips - Contestar
Its fine… You just need to remember not to put it on the recharging base… and the battery will be basically dead after 24 hour use.
flamespinner1 -
will any brand battery work or does the stock one have specific specs?
ThrowsMachete - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 43
Todo El Tiempo: 19,702
