Herramientas
Partes
Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...) Using a 3/8" Allen wrench, losen the nuts that hold the brake controls and gear shifters.
  • Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...)
  • Using a 3/8" Allen wrench, losen the nuts that hold the brake controls and gear shifters.
Agregar Comentario
Place an Allen wrench (size doesn't matter) under the bike grip Twist the grip back and forth while pulling on the Allen wrench to remove the grip. Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
  • Place an Allen wrench (size doesn't matter) under the bike grip
  • Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Slide off the gear shifters. Slide off the brake controls.
  • Slide off the gear shifters.
  • Slide off the brake controls.
Agregar Comentario
Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove. Lift the handlebars from the bike frame. Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
  • Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
  • Lift the handlebars from the bike frame.
  • Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
  • Sit on the bike and make final adjustments to the positioning of the brakes and gears.
Agregar Comentario
Conclusión
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
Jon Ribera
Miembro Desde 26/09/12
63 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 7-49, Forte Fall 2012 Miembro de Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 1,514
