Introducción
This guide demonstrates how to remove and replace a rear rack from the Raleigh M20 bicycle. This requires the removal of the old rear rack before replacing the new rear rack.
Make sure that the bike is upright and stable. With both hands, place the rear rack on the rear wheel of the bike. Take note of where the rear rack will attach on the bike.
  • Make sure that the bike is upright and stable.
  • With both hands, place the rear rack on the rear wheel of the bike. Take note of where the rear rack will attach on the bike.
  • Make sure that the rear rack is fitted on the bike.
Agregar Comentario
Place a screw to attach the rear rack to the frame of the tire. Tighten the screw with a philips screwdriver by turning it in a clockwise direction. Repeat the steps above on the other side of the bike.
  • Place a screw to attach the rear rack to the frame of the tire.
  • Tighten the screw with a philips screwdriver by turning it in a clockwise direction.
  • Repeat the steps above on the other side of the bike.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Place the metal holder to be even with the bar sticking out of the rear rack. Line up the holes. Place a bolt to attach them together. Use a philips screwdriver to tighten the bolts.
  • Place the metal holder to be even with the bar sticking out of the rear rack.
  • Line up the holes. Place a bolt to attach them together.
  • Use a philips screwdriver to tighten the bolts.
  • Do this for both sides.
Agregar Comentario
Make sure that the rear rack is even. If it is not, redo the previous step. Locate the screws on top of the rear rack. Tighten the screws using a philips screwdriver.
  • Make sure that the rear rack is even. If it is not, redo the previous step.
  • Locate the screws on top of the rear rack. Tighten the screws using a philips screwdriver.
  • Once the screws are tightened, you are done.
Agregar Comentario
Conclusión
To detach the rear rack, follow the instructions of this guide in the reverse order.
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 7-49, Forte Fall 2012 Miembro de Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 5
Últimos 30 Días: 24
Todo El Tiempo: 2,276
