Introducción
Follow these steps to disassemble the drill and replace the planetary gear for the RIDGID R84015 X2 power drill.
Partes
No se requieren partes.
Using a Torx T20 screwdriver, remove the four screws attaching the back plate. Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
Agregar Comentario
Remove the five screws attaching the drill handle.
  • Remove the five screws attaching the drill handle.
Agregar Comentario
Remove the 4 screws attaching the front of the casing. Remove the 4 screws attaching the front of the casing.
  • Remove the 4 screws attaching the front of the casing.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Unscrew the four screws at the rear of the plastic gear chamber.
  • Unscrew the four screws at the rear of the plastic gear chamber.
Agregar Comentario
Remove the motor from the drill. NOTE: Handle the gear chamber with caution as the gears are now loose.
  • Remove the motor from the drill.
  • NOTE: Handle the gear chamber with caution as the gears are now loose.
Agregar Comentario
Remove the four screws that attach the plastic gear chamber.
  • Remove the four screws that attach the plastic gear chamber.
  • Remove the plastic gear chamber.
Agregar Comentario
Remove each component from the gear assembly. Remove each component from the gear assembly.
  • Remove each component from the gear assembly.
Agregar Comentario
Linea de Meta
2 personas más completaron esta guía.
Evan Long
Miembro Desde 15/04/10
232 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 15-48, Garner Spring 2010 Miembro de Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Miembros
5 Guías creadas
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 12
Todo El Tiempo: 5,344
