Saltar al contenido principal
RCX 1.0 Batteries Replacement
  1. RCX 1.0 Batteries Replacement, Batteries: paso 1, imagen 1 de 1
    • Place the RCX on a flat surface.
  2. RCX 1.0 Batteries Replacement: paso 2, imagen 1 de 1
    • Flip the RCX over so its black IR window is facing away from you.
  3. RCX 1.0 Batteries Replacement: paso 3, imagen 1 de 1
    • Remove the gray battery cover by lifting from the front (near the IR window). Raise it at an angle and remove it to reveal the green battery compartment.
    • You can now remove the batteries and insert new ones.
Conclusión
To reassemble your device, follow these instructions in reverse order. The orientation of the gray battery cover doesn't matter.
3 personas más completaron esta guía.
notexactly
Miembro Desde 05/18/10
375 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 2,626
