Saltar al contenido principal
RCA CC310 Viewfinder Replacement
Qué necesitas
  1. RCA CC310 Viewfinder Replacement, Viewfinder: paso 1, imagen 1 de 2 RCA CC310 Viewfinder Replacement, Viewfinder: paso 1, imagen 2 de 2
    • Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
    • Pushing the viewfinder assembly to the right makes lifting the flap easier.
    • Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
  2. RCA CC310 Viewfinder Replacement: paso 2, imagen 1 de 3 RCA CC310 Viewfinder Replacement: paso 2, imagen 2 de 3 RCA CC310 Viewfinder Replacement: paso 2, imagen 3 de 3
    • Unscrew the 7mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable connects off of the viewfinder assembly.
    • Disconnect the cable inside by pulling it apart.
  3. RCA CC310 Viewfinder Replacement: paso 3, imagen 1 de 2 RCA CC310 Viewfinder Replacement: paso 3, imagen 2 de 2
    • Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up and remove.
  4. RCA CC310 Viewfinder Replacement: paso 4, imagen 1 de 1
    • Flip back the viewfinder access tab.
    • Unscrew the 7.0mm ph #0 screw next to the mirror.
  5. RCA CC310 Viewfinder Replacement: paso 5, imagen 1 de 3 RCA CC310 Viewfinder Replacement: paso 5, imagen 2 de 3 RCA CC310 Viewfinder Replacement: paso 5, imagen 3 de 3
    • Lift off both sides of the plastic assembly.
    • When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
  6. RCA CC310 Viewfinder Replacement: paso 6, imagen 1 de 2 RCA CC310 Viewfinder Replacement: paso 6, imagen 2 de 2
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  7. RCA CC310 Viewfinder Replacement: paso 7, imagen 1 de 3 RCA CC310 Viewfinder Replacement: paso 7, imagen 2 de 3 RCA CC310 Viewfinder Replacement: paso 7, imagen 3 de 3
    • Lift plastic housing and guide the wires from underneath.
    • Lift out the entire circuit board and viewfinder.
    • Replace entire circuit board and viewfinder assembly.
Conclusión
Oliver Adams
Miembro Desde 01/19/11
629 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 5-20, Amido Winter 2011 Miembro de Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Miembros
7 Guías creadas
Un comentario
do you know where i can find a relacement one of these parts
Connor Byrley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 2,268
