Introducción
Replacing the onboard speaker for the RCA CC310.
Remove the 6-7.9mm ph#0 screws on the back and bottom. Remove the one 3.8mm ph#0 screw on the bottom.
  • Remove the 6-7.9mm ph#0 screws on the back and bottom.
  • Remove the one 3.8mm ph#0 screw on the bottom.
  • Remove the two 7.5mm ph#0 screws on the back and bottom.
Agregar Comentario
Remove 5.8mm ph#1 screw from the side button panel. Slide the viewfinder all the way to the right and remove the 7.9mm ph#0 screw.
  • Remove 5.8mm ph#1 screw from the side button panel.
  • Slide the viewfinder all the way to the right and remove the 7.9mm ph#0 screw.
Agregar Comentario
Pry along the seam on the top side near the buttons with a spudger. Pry along the seam on the top side near the buttons with a spudger.
  • Pry along the seam on the top side near the buttons with a spudger.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Pull the left panel away from the rest of the camcorder. Unplug the red speaker cable located at the rear of the device.
  • Pull the left panel away from the rest of the camcorder.
  • Unplug the red speaker cable located at the rear of the device.
  • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
Agregar Comentario
Unplug the red cable connecting the speaker to the motherboard. Unplug the red cable connecting the speaker to the motherboard.
  • Unplug the red cable connecting the speaker to the motherboard.
Agregar Comentario
Locate the speaker on the removed panel. Find the groove on the top left side of the speaker. Pry the plastic up with a spudger until the glue breaks and the speaker is detached.
  • Locate the speaker on the removed panel. Find the groove on the top left side of the speaker.
  • Pry the plastic up with a spudger until the glue breaks and the speaker is detached.
Agregar Comentario
Break the plastic pieces holding the cable to the panel.
  • Break the plastic pieces holding the cable to the panel.
  • Glue the new cables, with a hot glue gun, back to the panel after replacing the speaker.
Agregar Comentario
Glue the new speaker to the panel. Plug the cable back into the motherboard. Plug the cable back into the motherboard.
  • Glue the new speaker to the panel.
  • Plug the cable back into the motherboard.
Agregar Comentario
Conclusión
Oliver Adams
Miembro Desde 19/01/11
620 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 5-20, Amido Winter 2011 Miembro de Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 2
Todo El Tiempo: 809
