Introducción
Upgrade your RAM for an instant increase in speed.
Qué necesitas
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Use your fingertips to pull the two RAM arms away from the sides of the RAM chip. The chip should pop up slightly.
Pull the RAM chip away from its socket and remove it from the logic board.
24 personas más completaron esta guía.
Documentos Adjuntos
Un comentario
What is the maximum ram that I can bump up this system to?
