Introducción
Save money by replacing your broken LCD element.
Use a coin to turn the battery locking screw 90 degrees to the right.
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
What can I say?
It is certainly do able. I just completed it. Took me 2 hours. The most important tool you'll need is patience - bag full of patience!!
Gopal - Contestar
Took 3 1/2 to 4 hours for someone who is handy but has never opened a computer before. Not so bad and it was a fun learning experience.
Nomad Toes - Contestar
Quote from Nomad Toes:
Weird. I posted this on Step 1 of replacing the optical drive, but it showed up on the RAM page since Step 1 is the same. Replacing the RAM takes 10 minutes.
Open the computer and rotate the display as far as possible.
  • Open the computer and rotate the display as far as possible.
  • Remove the T6 Torx screw from the bottom left corner of the display assembly. The computer casing will not allow the screwdriver to be inserted directly into the screw, so be careful not to strip the screw.
Agregar Comentario
Remove the T6 Torx screw from the bottom right corner of the display assembly.
  • Remove the T6 Torx screw from the bottom right corner of the display assembly.
  • To avoid cross-threading these screws during reinstallation, use a pair of tweezers to start each screw in its hole before using your Torx screwdriver to tighten them.
Agregar Comentario
The next steps involve the use of plastic opening tools and spudgers which will probably be ruined in the process. Have a few spares of each tool handy. Insert a plastic opening tool between the left edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD. Rotate the tool away from the LCD to pop the rear bezel off the tabs on the front display bezel.
  • The next steps involve the use of plastic opening tools and spudgers which will probably be ruined in the process. Have a few spares of each tool handy.
  • Insert a plastic opening tool between the left edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
  • Rotate the tool away from the LCD to pop the rear bezel off the tabs on the front display bezel.
  • Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
  • Freeing these tabs may require some force. Be sure to support the display assembly with your other hand to avoid putting too much strain on the hinges.
Agregar Comentario
Insert a plastic opening tool between the right edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD. Rotate the tool away from the LCD to pop the rear bezel off the tabs on the front display bezel. Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
  • Insert a plastic opening tool between the right edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
  • Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Agregar Comentario
Close the display. The rear display bezel is still attached to the display via the antenna cables. Lift the bottom edge of the rear display bezel up about an inch.
  • Close the display.
  • The rear display bezel is still attached to the display via the antenna cables.
  • Lift the bottom edge of the rear display bezel up about an inch.
  • Slide the rear display bezel forward to release the clips along the top edge of the display.
  • Rotate the rear display bezel away from the display and lay it next to the computer.
Agregar Comentario
Remove the Phillips screw securing the inverter board.
  • Remove the Phillips screw securing the inverter board.
Agregar Comentario
Insert the pointed end of the a spudger between the protective tape and the inverter board. Carefully pull up with the spudger to lift the inverter board out enough to access the connector cables.
  • Insert the pointed end of the a spudger between the protective tape and the inverter board.
  • Carefully pull up with the spudger to lift the inverter board out enough to access the connector cables.
  • Once you can easily grab the board, pull it up enough to gain access to the inverter board's output connector.
    • Gently remove the board in order to avoid damaging any wires or connectors.
Agregar Comentario
Disconnect the cable by pulling the connector away from the inverter board's socket.
  • Disconnect the cable by pulling the connector away from the inverter board's socket.
Agregar Comentario
Remove the two Phillips screws from both sides of the display (four in total). Remove the two Phillips screws from both sides of the display (four in total).
  • Remove the two Phillips screws from both sides of the display (four in total).
Agregar Comentario
Remove any tape on the display data cable. Pull the display data cable connector away from its socket to disconnect it from the LCD.
  • Remove any tape on the display data cable.
  • Pull the display data cable connector away from its socket to disconnect it from the LCD.
Agregar Comentario
Open the display slightly.
  • Open the display slightly.
  • Push the LCD away from the front display bezel near its top edge.
  • Remove the LCD, being wary of any cables that may get caught
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Documentos Adjuntos
Matthew Newsom
Miembro Desde 05/01/10
31,474 Reputación
93 Guías creadas
Thanks for your guide!
There is a little mistake. The 2 screws at the bottom left and right corner of the display assembly, are not torx T6, They are Hex 1.5mm/1/16". you should use Hex Key with Ball End to remove them."Ball End" ones can work within a angle about 50 degree.
Terrance - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 26
Todo El Tiempo: 14,796
