Saltar al contenido principal
PowerBook G3 Wallstreet PC Card Cage Replacement
Qué necesitas
  1. PowerBook G3 Wallstreet PC Card Cage Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
  2. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 2, imagen 1 de 1
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
  3. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 4, imagen 1 de 1
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
  4. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 5, imagen 1 de 1
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
  5. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 6, imagen 1 de 1
    • Your laptop should look approximately like this.
  6. PowerBook G3 Wallstreet PC Card Cage Replacement, Heat Shield: paso 7, imagen 1 de 1
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
  7. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 8, imagen 1 de 1
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
  8. PowerBook G3 Wallstreet PC Card Cage Replacement, Hard Drive: paso 9, imagen 1 de 1
    • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
  9. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 10, imagen 1 de 1
    • Grasp the hard drive bracket on the left side and pull up and to the left.
  10. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 11, imagen 1 de 1
  11. PowerBook G3 Wallstreet PC Card Cage Replacement, Processor: paso 12, imagen 1 de 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Remove the processor by sliding it up and to the right.
    • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
    • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
  12. PowerBook G3 Wallstreet PC Card Cage Replacement, Modem: paso 13, imagen 1 de 1
    • Remove the single Phillips screw from the modem.
    • Disconnect the orange PMU cable by pulling it directly up.
  13. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 14, imagen 1 de 1
    • Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
    • Remove the modem by sliding it up and to the right.
  14. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 15, imagen 1 de 1
  15. PowerBook G3 Wallstreet PC Card Cage Replacement, Clutch Cover: paso 16, imagen 1 de 1
    • Push the display back so that it lies flat.
    • Slip a spudger or your index finger under the clutch cover near the power button and pull upward until you feel it come free.
    • Repeat the previous step on the left side.
  16. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 17, imagen 1 de 1
    • Lift the clutch cover off by rotating it up and then toward you.
  17. PowerBook G3 Wallstreet PC Card Cage Replacement, Display: paso 18, imagen 1 de 1
    • Disconnect the orange display data cable on the left side of the computer. Grasp the cable near the connector and pull directly up.
  18. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 19, imagen 1 de 1
    • Disconnect the orange display inverter cable on the right side of the computer. Grasp the cable near the connector and pull directly up.
    • Make sure that both cables are free from the plastic casing before proceeding to the next step.
  19. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 20, imagen 1 de 1
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black T8 Torx screws.
  20. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 21, imagen 1 de 1
    • Turn the laptop back around so that the screen faces you.
    • Adjust the display so that it is in a vertical position.
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts
  21. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 22, imagen 1 de 1
    • Your laptop should look like this.
  22. PowerBook G3 Wallstreet PC Card Cage Replacement, Upper Case: paso 23, imagen 1 de 1
    • Remove the four T8 Torx screws from the upper case.
  23. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 24, imagen 1 de 1
    • Turn the laptop over.
    • Remove the eight T8 Torx screws from the bottom casing.
    • There are two longer screws in the front left and front right corners; make sure to put them back in the proper place when reassembling.
  24. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 25, imagen 1 de 1
    • Disengage the small locking tab by pressing in on the upper case to the right of the PMU connector.
    • Lift the upper case up just enough so that the tab rests on its metal bracket.
  25. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 26, imagen 1 de 1
    • Grasp the upper case near the back left corner and lift up partly so that you can access and disconnect the audio in/out cable from the sound card in the upper right corner of the case.
    • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cable.
    • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
  26. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 27, imagen 1 de 1
  27. PowerBook G3 Wallstreet PC Card Cage Replacement, Power Card: paso 28, imagen 1 de 1
    • Remove the single black T8 Torx screw from the power card.
    • Grasp the power card near the black plastic shield toward the center of the case and lift up.
    • Occasionally, a post connecting the power card to the logic board will come out with the power card.
    • Lift the sound card out by pulling up on both the right and left sides.
    • If the sound card sticks, pull the black metal wall of the casing toward you while lifting the right side of the sound card up.
    • Disconnect the fan connector from the logic board.
    • Remove the fan by pulling it directly up.
  28. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 31, imagen 1 de 1
  29. PowerBook G3 Wallstreet PC Card Cage Replacement, Logic Board: paso 32, imagen 1 de 1
    • Turn the laptop around so that the front is facing you.
    • The post connecting the power card to the logic board may still be attached to the board. Remove the post using needle-nose pliers.
    • Gently lift the front edge of the logic board and then pull it toward you.
  30. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 33, imagen 1 de 1
  31. PowerBook G3 Wallstreet PC Card Cage Replacement, PC Card Cage: paso 34, imagen 1 de 1
    • Turn the logic board over.
    • Remove the four T6 Torx screws.
    • Lift the thin metal bar off the logic board.
  32. PowerBook G3 Wallstreet PC Card Cage Replacement: paso 35, imagen 1 de 1
    • Clasp the PC card cage between your thumb and index finger and lift it directly upward.
Conclusión
3 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 3,499
