Introducción
The inverter powers the LCD backlight and is not a difficult part to replace.
Turn the computer so that the ports are facing you.
  • Turn the computer so that the ports are facing you.
  • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
Agregar Comentario
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
Agregar Comentario
Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
  • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
  • In order to replace the keyboard, you must first remove the modem.
Agregar Comentario
Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
Agregar Comentario
Lift the heat shield up and pull it toward you.
  • Lift the heat shield up and pull it toward you.
Agregar Comentario
Your laptop should look approximately like this.
  • Your laptop should look approximately like this.
Agregar Comentario
Pull the battery cable directly up from the logic board.
  • Pull the battery cable directly up from the logic board.
Agregar Comentario
Remove the battery from its holder by pulling up and to the left.
  • Remove the battery from its holder by pulling up and to the left.
Agregar Comentario
Remove the two silver Phillips screws from the modem.
  • Remove the two silver Phillips screws from the modem.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
Agregar Comentario
Disconnect the cable from the right side of the modem.
  • Disconnect the cable from the right side of the modem.
Agregar Comentario
Agregar Comentario
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Agregar Comentario
Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
  • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
  • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
Agregar Comentario
Agregar Comentario
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Pull the RAM chip out.
  • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
Agregar Comentario
Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
  • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
  • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
Agregar Comentario
Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
  • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
Agregar Comentario
Push the display back so that it lies flat.
  • Push the display back so that it lies flat.
Agregar Comentario
Slip a spudger or your index finger under the clutch cover near the power button and pull gently upward until you feel it come free.
  • Slip a spudger or your index finger under the clutch cover near the power button and pull gently upward until you feel it come free.
  • Repeat the previous step on the left side.
Agregar Comentario
Lift the clutch cover up and off, rotating it toward yourself.
  • Lift the clutch cover up and off, rotating it toward yourself.
Agregar Comentario
Grasp the orange display data cable and disconnect it from the logic board.
  • Grasp the orange display data cable and disconnect it from the logic board.
  • Pull the display cable straight up so that it is vertical.
Agregar Comentario
Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
  • Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
  • There are two tabs that hold the display inverter in place that you need to get past in order to pull the board free.
Agregar Comentario
Disconnect the white inverter cable connector from the right end of the board.
  • Disconnect the white inverter cable connector from the right end of the board.
Agregar Comentario
Disconnect the inverter plug, pulling directly up from the logic board.
  • Disconnect the inverter plug, pulling directly up from the logic board.
Agregar Comentario
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 24/09/09
1 Reputación
750 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 4,119
