Introducción
If your keyboard is malfunctioning you can remove the keyboard to clean it. If that doesn't solve your problem you will need to replace the keyboard.
Partes
No se requieren partes.
Close the screen and turn the PowerBook over. Orient the computer so the text of the label is right side up.
  • Close the screen and turn the PowerBook over. Orient the computer so the text of the label is right side up.
Agregar Comentario
Press and hold the button on the left of the front side and slide the battery out. Press and hold the button on the left of the front side and slide the battery out.
  • Press and hold the button on the left of the front side and slide the battery out.
Agregar Comentario
With a T8 torx screwdriver, remove the three 24mm torx screws along the middle of the back panel.
  • With a T8 torx screwdriver, remove the three 24mm torx screws along the middle of the back panel.
Agregar Comentario
Turn the computer over and open the display. You should see that the keyboard is loose. Before attempting to remove the keyboard, note that a ribbon cable connects  the keyboard to the logic board. Improper removal may damage your keyboard. Carefully lift the front of the keyboard up slightly and then slide the keyboard towards yourself.
  • Turn the computer over and open the display. You should see that the keyboard is loose.
  • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
  • Carefully lift the front of the keyboard up slightly and then slide the keyboard towards yourself.
  • Then carefully lift the top half of the keyboard and rotate it towards yourself.
Agregar Comentario
Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port. Gently remove the ribbons from its tabs
  • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
  • Gently remove the ribbons from its tabs
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 24-59, Amido Spring 2011 Miembro de Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 1,679
