Saltar al contenido principal
PowerBook 3400 M3553 Battery Replacement
  1. PowerBook 3400 M3553 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 Battery Replacement: paso 2, imagen 1 de 2 PowerBook 3400 M3553 Battery Replacement: paso 2, imagen 2 de 2
    • Hold the button on the front left side and slide the battery out.
Conclusión
To reassemble your device, simply slide the battery back into the slot until it snaps into place.
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 24-59, Amido Spring 2011 Miembro de Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Miembros
9 Guías creadas
Un comentario
hey, I was wandering how do i replace the PRAM battery. If you know how i will apriciatte if you post a guide of how to do it. thanks
TOBI Pugli - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 2,416
