Remove the Ni-Cad battery from the PowerBook 180. Slide the arrows toward the front of the computer until the battery can slide out.
  • Remove the Ni-Cad battery from the PowerBook 180.
  • Slide the arrows toward the front of the computer until the battery can slide out.
Agregar Comentario
Removing the screws securing the bottom plate from the PowerBook 180. There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
  • Removing the screws securing the bottom plate from the PowerBook 180.
  • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Your computer should look like the two pictures after the bottom plate is removed. Your computer should look like the two pictures after the bottom plate is removed.
  • Your computer should look like the two pictures after the bottom plate is removed.
Agregar Comentario
Locate the modem board, which is next to the DC-in port. There are two Torx T8 screws marked in red in the pictures.  Remove these screws and pull up on the modem board to remove.
  • Locate the modem board, which is next to the DC-in port.
  • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
  • To reassemble your PowerBook, follow these instructions in reverse.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Jack Byrnes
Miembro Desde 17/10/10
1,148 Reputación
2 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
276 Miembros
718 Guías creadas
Great guide. Worked for me of the Powerbook 140. Thanks!
Jack - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 961
