Introducción
These steps will show you how to install the top left cooling fan unit.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
  • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
  • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
Agregar Comentario
Remove all the cables, including the power cables before opening the unit.
  • Remove all the cables, including the power cables before opening the unit.
Agregar Comentario
Lift the tab to unlock the side panel. The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  • Lift the tab to unlock the side panel.
  • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
Agregar Comentario
Remove the air deflector (the clear plastic cover) by pulling on the handle. Remove the air deflector (the clear plastic cover) by pulling on the handle. Remove the air deflector (the clear plastic cover) by pulling on the handle.
  • Remove the air deflector (the clear plastic cover) by pulling on the handle.
Agregar Comentario
Locate the top left cooling fan unit.
  • Locate the top left cooling fan unit.
Agregar Comentario
Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
  • Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
    • It may be easier to reach the cables if you remove the PCI guide (next to the fan unit) first.
Agregar Comentario
After pulling out the fan unit, the area should look like this.
  • After pulling out the fan unit, the area should look like this.
Agregar Comentario
Conclusión
19 personas más completaron esta guía.
Salvador Aguilar
Miembro Desde 21/01/10
2,337 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-8, Forte Winter 2010 Miembro de Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Miembros
11 Guías creadas
Actually you do need to remove the plastic air deflector, as the fan in question is behind it.
Tim downing - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 13
Últimos 30 Días: 32
Todo El Tiempo: 16,940
