Saltar al contenido principal
Power Mac G5 Front Fan Assembly Replacement
  1. Power Mac G5 Front Fan Assembly Replacement, Side Panel: paso 1, imagen 1 de 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Front Fan Assembly Replacement: paso 2, imagen 1 de 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Front Fan Assembly Replacement: paso 3, imagen 1 de 2 Power Mac G5 Front Fan Assembly Replacement: paso 3, imagen 2 de 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Front Fan Assembly Replacement: paso 4, imagen 1 de 3 Power Mac G5 Front Fan Assembly Replacement: paso 4, imagen 2 de 3 Power Mac G5 Front Fan Assembly Replacement: paso 4, imagen 3 de 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Front Fan Assembly Replacement, Front Fan Assembly: paso 5, imagen 1 de 1
    • Locate the front fan assembly.
  6. Power Mac G5 Front Fan Assembly Replacement: paso 6, imagen 1 de 1
    • Pull the fan assembly out; it should slide out easily.
Conclusión
25 personas más completaron esta guía.
Adam
Miembro Desde 01/22/10
831 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-8, Forte Winter 2010 Miembro de Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 18,881
