Saltar al contenido principal
Power Mac G5 CD-ROM Drive Replacement
  1. Power Mac G5 CD-ROM Drive Replacement, Side Panel: paso 1, imagen 1 de 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 CD-ROM Drive Replacement: paso 2, imagen 1 de 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 CD-ROM Drive Replacement: paso 3, imagen 1 de 2 Power Mac G5 CD-ROM Drive Replacement: paso 3, imagen 2 de 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 CD-ROM Drive Replacement: paso 4, imagen 1 de 3 Power Mac G5 CD-ROM Drive Replacement: paso 4, imagen 2 de 3 Power Mac G5 CD-ROM Drive Replacement: paso 4, imagen 3 de 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 CD-ROM Drive Replacement, CD-ROM Drive: paso 5, imagen 1 de 1
    • Locate the CD-ROM Drive on the top left corner of desktop.
  6. Power Mac G5 CD-ROM Drive Replacement: paso 6, imagen 1 de 3 Power Mac G5 CD-ROM Drive Replacement: paso 6, imagen 2 de 3 Power Mac G5 CD-ROM Drive Replacement: paso 6, imagen 3 de 3
    • Pull and rotate latches to the left.
  7. Power Mac G5 CD-ROM Drive Replacement: paso 7, imagen 1 de 1
    • Wiggle and pull out the CD Drive.
  8. Power Mac G5 CD-ROM Drive Replacement: paso 8, imagen 1 de 2 Power Mac G5 CD-ROM Drive Replacement: paso 8, imagen 2 de 2
    • Detach the first cable from the CD-ROM drive.
    • Detach the second cable from the CD-ROM drive.
    • On some models, the IDE cable is stuck to the top of the CD-ROM with foam tape. It is easier to unplug the IDE connector from the motherboard, and de-route the IDE cable as you remove the drive.
  9. Power Mac G5 CD-ROM Drive Replacement: paso 9, imagen 1 de 1
    • After the CD-ROM drive is removed, the area should look like this.
Conclusión
43 personas más completaron esta guía.
Jessica Chaidez
Miembro Desde 01/13/10
7,965 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-8, Forte Winter 2010 Miembro de Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Miembros
20 Guías creadas
Un comentario
Is it possible to use an IDE to SATA connector? I want to install my Pioneer BDR burner to potentially use the PMG5 for data disc burning only. Any thoughts?
nirv - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 56
Todo El Tiempo: 34,637
