Introducción
Removing the CPU of the Power Mac G4 Quicksilver for replacement.
Partes
No se requieren partes.
The handle to open your computer is located on top of the right side panel.
  • The handle to open your computer is located on top of the right side panel.
Agregar Comentario
Grab the circular handle and pull outward. Grab the circular handle and pull outward.
  • Grab the circular handle and pull outward.
Agregar Comentario
Your computer is now open and ready for repair.
  • Your computer is now open and ready for repair.
Agregar Comentario
This is your Power Mac G4's video adapter.
  • This is your Power Mac G4's video adapter.
Agregar Comentario
Start by removing the screw holding the card to the chassis as shown.
  • Start by removing the screw holding the card to the chassis as shown.
Agregar Comentario
Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
  • Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
Agregar Comentario
With the tab and screw removed, lift the card straight out. When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
  • With the tab and screw removed, lift the card straight out.
  • When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
Agregar Comentario
First you want to remove the fan. Remove the two screws on the back of the computer in the upper left hand corner.
  • First you want to remove the fan. Remove the two screws on the back of the computer in the upper left hand corner.
Agregar Comentario
Remove the fan unit by pulling straight up and out. Be carful not to rip out the cord still attached to the motherboard. Remove it gently.
  • Remove the fan unit by pulling straight up and out.
  • Be carful not to rip out the cord still attached to the motherboard. Remove it gently.
Agregar Comentario
You need detach the heat sink from the CPU. Locate the four clamps holding it down, two on each side. Taking off the clamps can be difficult. Use a screwdriver to push down on the top of the clip. Then insert a spudger below the heat sink to pull it away from the board, releasing the heat sink.
  • You need detach the heat sink from the CPU. Locate the four clamps holding it down, two on each side.
  • Taking off the clamps can be difficult. Use a screwdriver to push down on the top of the clip. Then insert a spudger below the heat sink to pull it away from the board, releasing the heat sink.
Agregar Comentario
Pull the heat sink up and off of the CPU. Pull the heat sink up and off of the CPU.
  • Pull the heat sink up and off of the CPU.
Agregar Comentario
Remove the four screws holding the CPU to the motherboard.
  • Remove the four screws holding the CPU to the motherboard.
Agregar Comentario
Now you can remove the CPU by pulling it straight up from the motherboard. Be very careful when you detach the CPU. There is a connector that has hundreds of little  prongs. You must not bend or break any of them! Be extremely careful.
  • Now you can remove the CPU by pulling it straight up from the motherboard.
  • Be very careful when you detach the CPU. There is a connector that has hundreds of little prongs. You must not bend or break any of them! Be extremely careful.
Agregar Comentario
You can now replace the CPU.
  • You can now replace the CPU.
Agregar Comentario
Conclusión
9 personas más completaron esta guía.
Ryan Bylard
Miembro Desde 20/01/10
1,230 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 14-41, Regan Winter 2010 Miembro de Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
4 Miembros
10 Guías creadas
Removing graphics (video) card is not necessary. Also, removing the clips which retain heat-sink can be accomplished by using a flat-blade (-) screwdriver to carefully pry them from the finned aluminum assembly. Other than these two suggestions, guide is succinct and accurate.
analogcd - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 19
Todo El Tiempo: 9,535
