Introducción
The Power Mac G4 MDD Supports four IDE hard drives in two separate drive cages on two different IDE channels (the computer has three IDE channels for six IDE drives total).
Partes
No se requieren partes.
The Power Mac G4 MDD: the last, and the fastest G4-based Mac.  This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz). Six USB ports.
  • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
  • Six USB ports.
  • Four FireWire ports.
  • Assorted SCSI (SCSI50/SCSI68)
  • Assorted Audio
  • Video (ADC & DVI)
  • Networking (RJ-45 Ethernet/56k Modem)
  • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
Agregar Comentario
Pull on the side lever and lower the side of the case. Pull on the side lever and lower the side of the case. Pull on the side lever and lower the side of the case.
  • Pull on the side lever and lower the side of the case.
Agregar Comentario
The hard drive cages are located here.
  • The hard drive cages are located here.
Agregar Comentario
Cage 1 Start by removing this screw. Remove the IDE ribbon cable from the motherboard.
  • Cage 1
  • Start by removing this screw.
  • Remove the IDE ribbon cable from the motherboard.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Now, remove the power connecton from the drives. Now, remove the power connecton from the drives.
  • Now, remove the power connecton from the drives.
Agregar Comentario
Now, push this tab down, and pull the cage towared you. Now, you can set cage 1 aside. Now, you can set cage 1 aside.
  • Now, push this tab down, and pull the cage towared you.
  • Now, you can set cage 1 aside.
Agregar Comentario
Cage 2: Remove this Phillips screw:
  • Cage 2:
  • Remove this Phillips screw:
  • Disconnect this IDE ribbon cable from the logic board.
Agregar Comentario
It's likely that there is a cable clip holding the ribbon cable to the case. To remove it, push the end, and it should pop up.
  • It's likely that there is a cable clip holding the ribbon cable to the case.
  • To remove it, push the end, and it should pop up.
Agregar Comentario
With the clip free, pull on this tab, lift the cage up, until it clicks, and pull it away. Now, set the cage on top of the CPU, and remove the power connectors. Now, set the cage on top of the CPU, and remove the power connectors.
  • With the clip free, pull on this tab, lift the cage up, until it clicks, and pull it away.
  • Now, set the cage on top of the CPU, and remove the power connectors.
Agregar Comentario
Once the cables are free, set the drive cage aside. To remove the hard drives from the cages, remove the four screws on the sides of the cage that are connected to the drives, than slide the drives out.
  • Once the cables are free, set the drive cage aside.
  • To remove the hard drives from the cages, remove the four screws on the sides of the cage that are connected to the drives, than slide the drives out.
  • The two cages are cross compatible and can be put in either rack.
  • The MDD does not have a 128GB drive limit like older macs, My MDD has 3 Drives (A 400GB Hitatchi Deskstar, 40GB Seagate Baracuda 7200.7, and a 30GB Quantum Fireball LCT).
  • Note the ID jumpers on the two drive set. One is set to Master, the other to slave. A single drive can be set to Cable Select.
Thanks - excellent tutorial!
Question: If you have a single internal drive, and a connected extrenal drive via firewire or usb, what jumper setting should be set for the internal drive and the external drive? Booting into Mac OS 9 natively (not via Classic) on the internal drive seems to be sensitive to the jumper settings and I’m having issues getting it to work.
LTG Seb - Contestar
Conclusión
28 personas más completaron esta guía.
Chris Green
Miembro Desde 11/10/09
31,845 Reputación
46 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
275 Miembros
715 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 41
Últimos 30 Días: 191
Todo El Tiempo: 36,938
