Introducción
Removing the Hard Drive.
Partes
No se requieren partes.
Pull on outer latch. Lower door until it is level with your work surface.
  • Pull on outer latch.
  • Lower door until it is level with your work surface.
  • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
Agregar Comentario
Remove the ribbon cable and power cable from the Hard Drive. Remove the ribbon cable and power cable from the Hard Drive.
  • Remove the ribbon cable and power cable from the Hard Drive.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the screw which holds the Hard Drive tray in place.
  • Remove the screw which holds the Hard Drive tray in place.
Agregar Comentario
Slide the Hard Drive tray out of the computer.
  • Slide the Hard Drive tray out of the computer.
Agregar Comentario
To remove the Hard Drive from the tray, unscrew the 4 screws on the bottom of the tray.
  • To remove the Hard Drive from the tray, unscrew the 4 screws on the bottom of the tray.
what i do next?
Isaac Cabrera - Contestar
Linea de Meta
27 personas más completaron esta guía.
Justin Petrilli
Miembro Desde 21/01/10
2,598 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 13-24, Maness Winter 2010 Miembro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Miembros
13 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 13
Últimos 30 Días: 99
Todo El Tiempo: 17,439
