Partes
No se requieren partes.
Unscrew and remove the four screws from the left side of the camera (from the screen's view) Unscrew and remove the four screws from the left side of the camera (from the screen's view)
  • Unscrew and remove the four screws from the left side of the camera (from the screen's view)
Agregar Comentario
Unscrew and remove the three screws from the bottom of the camera
  • Unscrew and remove the three screws from the bottom of the camera
Agregar Comentario
Unscrew and remove the two screws from the right side of the camera. Unscrew and remove the two screws from the right side of the camera.
  • Unscrew and remove the two screws from the right side of the camera.
Agregar Comentario
Open the battery flap and remove the batteries. Keep the battery flap open.
  • Open the battery flap and remove the batteries.
  • Keep the battery flap open.
Agregar Comentario
Use a spudger to gently separate the two halves of the camera's outer casing.
  • Use a spudger to gently separate the two halves of the camera's outer casing.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Gently pull the half of the case with the screen (the back half) from the rest of the camera.
  • Gently pull the half of the case with the screen (the back half) from the rest of the camera.
  • Be sure not too pull to hard. The screen is still attached to the motherboard. If you pull too hard you will rip it.
Agregar Comentario
The back half (the half with the screen on it) should now be separate from the rest of the camera, but still attached by the ribbon. The back half (the half with the screen on it) should now be separate from the rest of the camera, but still attached by the ribbon.
  • The back half (the half with the screen on it) should now be separate from the rest of the camera, but still attached by the ribbon.
Agregar Comentario
Use a spudger to lift the black flap that clamps the ribbon towards you. When the black flap is open it will be straight up. (like in the second picture)
  • Use a spudger to lift the black flap that clamps the ribbon towards you.
  • When the black flap is open it will be straight up. (like in the second picture)
Agregar Comentario
Now that the black flap is open, gently pull the ribbon out.
  • Now that the black flap is open, gently pull the ribbon out.
  • You should now have the back half of the camera completely separate from the rest of the camera.
Agregar Comentario
This is what the back half of the camera should look like. This is what the rest of the camera will look like.
  • This is what the back half of the camera should look like.
  • This is what the rest of the camera will look like.
Agregar Comentario
Unscrew and remove two screws from the logic board.
  • Unscrew and remove two screws from the logic board.
Agregar Comentario
Pull the front half off of the logic board.
  • Pull the front half off of the logic board.
Agregar Comentario
This will be the front half of the outer case.
  • This will be the front half of the outer case.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 3-4, Johann Summer 2010 Miembro de Cal Poly, Team 3-4, Johann Summer 2010
CPSU-JOHANN-R10S3G4
4 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,229
