Saltar al contenido principal
Polaroid One-Step 600 Lens Replacement
Qué necesitas
  1. Polaroid One-Step 600 Lens Replacement, Lens: paso 1, imagen 1 de 3 Polaroid One-Step 600 Lens Replacement, Lens: paso 1, imagen 2 de 3 Polaroid One-Step 600 Lens Replacement, Lens: paso 1, imagen 3 de 3
    • Open the flash compartment of the camera so it makes a 30 degree angle with the horizontal.
  2. Polaroid One-Step 600 Lens Replacement: paso 2, imagen 1 de 3 Polaroid One-Step 600 Lens Replacement: paso 2, imagen 2 de 3 Polaroid One-Step 600 Lens Replacement: paso 2, imagen 3 de 3
    • Separate the flash section of the camera from the main body by unhooking the sides with the spudger.
    • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  3. Polaroid One-Step 600 Lens Replacement: paso 3, imagen 1 de 3 Polaroid One-Step 600 Lens Replacement: paso 3, imagen 2 de 3 Polaroid One-Step 600 Lens Replacement: paso 3, imagen 3 de 3
    • Fully open the battery/ cartridge compartment by sliding the side tab toward you.
  4. Polaroid One-Step 600 Lens Replacement: paso 4, imagen 1 de 3 Polaroid One-Step 600 Lens Replacement: paso 4, imagen 2 de 3 Polaroid One-Step 600 Lens Replacement: paso 4, imagen 3 de 3
    • Insert spudger in between face of camera and sides where the four tabs are located.
    • BE CAREFUL! The button that is pressed to take a picture may pop out of the camera at this step.
  5. Polaroid One-Step 600 Lens Replacement: paso 5, imagen 1 de 2 Polaroid One-Step 600 Lens Replacement: paso 5, imagen 2 de 2
    • Once tabs are released, pull face of camera straight out.
  6. Polaroid One-Step 600 Lens Replacement: paso 6, imagen 1 de 1
    • Use spudger to twist the notch on the lens into the opening to remove it.
  7. Polaroid One-Step 600 Lens Replacement: paso 7, imagen 1 de 2 Polaroid One-Step 600 Lens Replacement: paso 7, imagen 2 de 2
    • Carefully use spudger to release lens, then lift lens out of camera with fingers.
    • CAUTION: LENS MAY POP OUT OF CAMERA; REMOVE CAREFULLY.
  8. Polaroid One-Step 600 Lens Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Clean old lens with a microfiber cloth or get a new lens to put back into the camera.
Conclusión
8 personas más completaron esta guía.
Doug Jimenez
Miembro Desde 01/21/10
538 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 16-31, Maness Winter 2010 Miembro de Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Miembros
6 Guías creadas
Un comentario
Hi, since you seem to know stuff about Polaroid cameras, I was wondering if you could help me figure out what is wrong with mine. I have a Polaroid Instant One-Step and whenever I take pictures, they never fully develop. They are a blue-ish hue and are never clear. Is this because of the lens do you think? Or something completely different?
Thanks
H.Rose - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 48
Todo El Tiempo: 16,148
