Saltar al contenido principal
Pokewalker Battery Replacement
Qué necesitas
  1. Pokewalker Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the Screw on the Back of the Pokewalker.
  2. Pokewalker Battery Replacement: paso 2, imagen 1 de 1
    • Remove the Screw with a Phillips #0 Screwdriver
    • The screw is attached to the rear case with washers. don't worry about losing it.
  3. Pokewalker Battery Replacement: paso 3, imagen 1 de 1
    • Remove the Rear Cover from the Device
  4. Pokewalker Battery Replacement: paso 4, imagen 1 de 1
    • Use the flat end of a Spudger to Remove the Battery
Conclusión
8 personas más completaron esta guía.
Winni Stuart
Miembro Desde 04/13/14
417 Reputación
2 Guías creadas
2 comentarios
The battery must be placed positive side facing up if I am correct.
I just dug my pokewalker out of my closet. Been years since it has been used. Putting in an effort to get it running again.
Thanks for the tutorial.
Jake Allen - Contestar
I just got my Pokéwalker up and running again as well. Nintendo's stuff is always so well made.
signature -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 17
Ultimos 7 días: 126
Ultimos 30 días: 553
Todo El Tiempo: 25,379
