Saltar al contenido principal
Playstation 3 Fan Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Playstation 3 Fan Replacement, Top Cover: paso 1, imagen 1 de 2 Playstation 3 Fan Replacement, Top Cover: paso 1, imagen 2 de 2
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Fan Replacement: paso 2, imagen 1 de 1
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Fan Replacement: paso 3, imagen 1 de 2 Playstation 3 Fan Replacement: paso 3, imagen 2 de 2
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Fan Replacement: paso 4, imagen 1 de 2 Playstation 3 Fan Replacement: paso 4, imagen 2 de 2
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Fan Replacement: paso 5, imagen 1 de 3 Playstation 3 Fan Replacement: paso 5, imagen 2 de 3 Playstation 3 Fan Replacement: paso 5, imagen 3 de 3
    • You can now lift off the top cover.
  6. Playstation 3 Fan Replacement, Power Supply: paso 6, imagen 1 de 2 Playstation 3 Fan Replacement, Power Supply: paso 6, imagen 2 de 2
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Playstation 3 Fan Replacement: paso 7, imagen 1 de 1
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Playstation 3 Fan Replacement: paso 8, imagen 1 de 2 Playstation 3 Fan Replacement: paso 8, imagen 2 de 2
    • Remove the power supply by lifting it straight up.
  9. Playstation 3 Fan Replacement, Motherboard Enclosure: paso 9, imagen 1 de 2 Playstation 3 Fan Replacement, Motherboard Enclosure: paso 9, imagen 2 de 2
    • Unplug the optical drive power cable.
    • Detach the ribbon cable that connects the optical drive to the motherboard.
    • Set the optical drive aside.
  10. Playstation 3 Fan Replacement: paso 10, imagen 1 de 2 Playstation 3 Fan Replacement: paso 10, imagen 2 de 2
    • Remove three screws (Phillips #2) from the wireless board and antenna.
    • Detach the ribbon cable that connects the wireless board to the motherboard.
  11. Playstation 3 Fan Replacement: paso 11, imagen 1 de 1
    • Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
  12. Playstation 3 Fan Replacement: paso 12, imagen 1 de 3 Playstation 3 Fan Replacement: paso 12, imagen 2 de 3 Playstation 3 Fan Replacement: paso 12, imagen 3 de 3
    • Remove the hard drive door with a spudger.
    • Lift the metal enclosure out of the plastic bottom case.
  13. Playstation 3 Fan Replacement, Fan: paso 13, imagen 1 de 1
    • Remove the three screws (Phillips #2).
    • Disconnect the fan's power cable.
    • Lift the fan straight up and out.
Conclusión
Una persona más ha completado esta guía.
iDeleted
Miembro Desde 07/07/10
2,101 Reputación
39 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,790
