Introducción
This guide takes your through the process of installing the right button board. This board controls the action, start, and select buttons.
Power off and remove the memory card. Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  • Power off and remove the memory card.
  • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Agregar Comentario
Using your fingernail or a spudger, pry open the accessory port cover on the top of the device. Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover. Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
  • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
Agregar Comentario
Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port. Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
Agregar Comentario
Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases. Continue working your way around the device gently prying it open. There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
  • Continue working your way around the device gently prying it open.
  • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
Agregar Comentario
Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together. Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
Agregar Comentario
Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
Agregar Comentario
Free the battery cable by gently prying up on the connection with a spudger.
  • Free the battery cable by gently prying up on the connection with a spudger.
Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
Jimbo Jones - Contestar
This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
ylimakiminna - Contestar
Yea I messed up there too. Is there a way to fix it?
Alethia Henry - Contestar
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Separate the front and rear cases.
  • Separate the front and rear cases.
Agregar Comentario
Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card. Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way. Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
  • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
Step 9-11 only apply to the 3G version of the PS Vita.
logicj83 - Contestar
Hello, I have the PCH-2001 model of the PS vita and the right analog stick went out. I ordered a replacement and the stick is slightly larger than the original. The original has a black rectangle on the back, the new version has the star version, which is what you have on this website as the replacement part. Any help here would be much appreciated. Thanks.
Ben Ragains - Contestar
Hook the spudger beneath the tab on the wireless card casing and release the tab. Peel up and remove the wireless card casing.
  • Hook the spudger beneath the tab on the wireless card casing and release the tab.
  • Peel up and remove the wireless card casing.
Agregar Comentario
Remove the two 4.4mm Phillips #00 screws on the wireless card. The wireless card will naturally pop out at an angle.
  • Remove the two 4.4mm Phillips #00 screws on the wireless card.
  • The wireless card will naturally pop out at an angle.
  • Pull out the wireless card.
Agregar Comentario
Pry up the right shoulder button casing with a spudger and set it aside. Pry up the right shoulder button casing with a spudger and set it aside. Pry up the right shoulder button casing with a spudger and set it aside.
  • Pry up the right shoulder button casing with a spudger and set it aside.
Agregar Comentario
Remove the translucent, plastic right shoulder button cover.
  • Remove the translucent, plastic right shoulder button cover.
Agregar Comentario
Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab. Using tweezers, slide the flex cable out of the socket. Using tweezers, slide the flex cable out of the socket.
  • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
  • Using tweezers, slide the flex cable out of the socket.
Agregar Comentario
Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing. Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
Agregar Comentario
Using the pointy end of a spudger, detach the antenna cable on the right button board. Remove the antenna cable.
  • Using the pointy end of a spudger, detach the antenna cable on the right button board.
  • Remove the antenna cable.
Agregar Comentario
Using a spudger, pry up and release the ZIF socket on the right button board. Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  • Using a spudger, pry up and release the ZIF socket on the right button board.
  • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
Agregar Comentario
Release the tab on the small flex cable socket by prying up the tab with a spudger. Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way. Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  • Release the tab on the small flex cable socket by prying up the tab with a spudger.
  • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
Agregar Comentario
Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard. Remove the metal bracket, using a spudger as necessary to lift it out. Remove the metal bracket, using a spudger as necessary to lift it out.
  • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
  • Remove the metal bracket, using a spudger as necessary to lift it out.
Agregar Comentario
Use a spudger to free the right button board by prying up from the bottom right corner of board. Gently lift the right button board out. Gently lift the right button board out.
  • Use a spudger to free the right button board by prying up from the bottom right corner of board.
  • Gently lift the right button board out.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Brittany McCrigler
Miembro Desde 05/03/12
78,373 Reputación
431 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
114 Miembros
5,903 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 13
Últimos 30 Días: 54
Todo El Tiempo: 3,945
