Introducción
Use this guide to replace the control board. Replacing the control board will provide a new mirror panel, power button, and eject button.
Turn the PS3 over and lay it on its backside.
  • Turn the PS3 over and lay it on its backside.
  • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
  • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
Agregar Comentario
Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
Agregar Comentario
Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
Agregar Comentario
Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
Its 4 screws beneath the blu-ray
Manuel - Contestar
Daniel Tlapa - Contestar
Can we edit this to say 4 screws?
revanantwraith - Contestar
I made the change from three to four screws, but you're able to edit the guides as well. If you want to edit something, you can click the Edit link on the right side of any guide step, or the Edit link at the top right of the page (sandwiched in-between View and History).
Taylor Arnicar -
Do you guys have a guide for the PS3 Slim Model 3001A. The fan is different than this model.
emknight04 - Contestar
3001a is basically same motherboard but cheaper plastic bd drive other than that its exactly the same until you get to the new slim line
Robert -
Anyone know an online retailer with a competitive price for the replacement fan?
Jared - Contestar
My PS3 had only three Torx screws. Having four in the diagram was initially confusing. Obviously they made a mid-stream change at some point (mine is several years old now).
corygbooker - Contestar
I've accidentally removed the ribbon cable from the blu-Ray drive and can not seem to figure out how to reconnect it. Can anyone help?
OneIfByLand - Contestar
Take the top off the drive, connect the ribbon to the motherboard then replace the drive sliding the ribbon through the slot on the bottom of the drive and reconnect to the laser.
KcXbox Repair -
pls help i have to tear down my ps3 slim but the 4 srews are very hard to take it out because there is a needle in the middle pls hep
Vincent Brabandt - Contestar
If the screw has a pin in the center, that means it is a security Torx meant to prevent tampering. To remove this screw, follow the guide I have linked below...
http://www.instructables.com/id/Removing...
Telpack - Contestar
Lift the top cover from its rear edge and rotate it toward the front of the PS3. Lift the top cover off the PS3.
  • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
  • Lift the top cover off the PS3.
Agregar Comentario
Use the tip of a spudger to pry the control board out of its housing within the lower case. Pull the control board ribbon cable away from its socket on the control board.
  • Use the tip of a spudger to pry the control board out of its housing within the lower case.
  • Pull the control board ribbon cable away from its socket on the control board.
Please do a review on how to do this on a Cech 3001b but only how to plug in the wire
Darian - Contestar
Conclusión
14 personas más completaron esta guía.
I have a PS3 slim that won't turn on, unfortunately my Power/eject button and ribbon cable are completely removed from my PS3. Can I turn it on without the button/ribbon cable?
wrestlemaniafreak - Contestar
I replaced the entire psu but without a standby light I have no idea if I'm close to powering it on. I suppose I could get a multimeter but I don't know what I'm testing. Any info would be appreciated.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 12
Últimos 30 Días: 90
Todo El Tiempo: 18,507
