Introducción
Replace your PlayStation 2's scratched-up or worn out top cover.
Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards. Use the flat edge of a metal spudger to pry the eight flat screw covers out. Remove the following eight screws securing the top cover to the bottom case:
  • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
  • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
  • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
Before proceeding to step 2, Take a look at your PS2, some PS2's have 10 screws (and screw covers) instead of 8 (i found them underneath the optical drive), these instructions have mislead me and i ended up breaking my top cover for my PS2.
Tristan - Contestar
Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
  • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
  • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Peel the warranty sticker (located next to the main power switch) straight away from the case.
  • Peel the warranty sticker (located next to the main power switch) straight away from the case.
  • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
Agregar Comentario
Flip the PlayStation 2 back to its original upside position. Lift the top cover off the bottom case.
  • Flip the PlayStation 2 back to its original upside position.
  • Lift the top cover off the bottom case.
  • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
  • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the bottom case.
Agregar Comentario
Conclusión
12 personas más completaron esta guía.
jwyoung
Miembro Desde 04/11/09
1,671 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 19-1, Maness Fall 2009 Miembro de Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 8
Últimos 7 Días: 23
Últimos 30 Días: 69
Todo El Tiempo: 10,809
