Introducción
Follow the procedure outlined in this guide to remove and install a broken audio or power jack.
Pry off the four white feet with the pointed end of the spudger
  • Pry off the four white feet with the pointed end of the spudger
Agregar Comentario
Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
Agregar Comentario
Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
  • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
  • The connectors on the panel are fragile and may break.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock. Electrical Connectors Ribbon Connectors
  • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
    • Electrical Connectors
    • Ribbon Connectors
  • The cables do not have a lot of slack in them. Be careful not to break the connectors.
  • One wire is soldered onto the bottom panel. Be careful not to break this bond.
Agregar Comentario
Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
  • Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
Agregar Comentario
Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
  • Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
Agregar Comentario
Separate the white suport bracket from the headphone/power electronics board.
  • Separate the white suport bracket from the headphone/power electronics board.
Agregar Comentario
Conclusión
Graham Rolph
Miembro Desde 18/04/13
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-48, Amido Spring 2013 Miembro de Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 8
Todo El Tiempo: 912
