Saltar al contenido principal
Pentax Optio WP Battery and SD Card Replacement
  1. Pentax Optio WP Battery and SD Card Replacement, Battery and SD Card: paso 1, imagen 1 de 1
    • The camera used to make this manual does not contain a battery or SD card
    • Orient the camera so you are looking at the bottom and the battery compartment is on the right hand side.
  2. Pentax Optio WP Battery and SD Card Replacement: paso 2, imagen 1 de 2 Pentax Optio WP Battery and SD Card Replacement: paso 2, imagen 2 de 2
    • Unlock the battery compartment by sliding the lock switch to the unlock position (away from the arrow).
    • Firmly push the battery cover to the right and swing open.
    • The battery will be located in the larger bottom slot. Slide the plastic orange tab to remove the battery.
    • The SD card will be located in the smaller, top slot. Push the SD card directly in to hear a small clicking sound. Then pull out the SD card.
Conclusión
Olivia Nixon
Miembro Desde 01/16/11
429 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 1-13, Amido Winter 2011 Miembro de Cal Poly, Team 1-13, Amido Winter 2011
CPSU-AMIDO-W11S1G13
5 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 34
Todo El Tiempo: 4,017
