Introducción
This guide will show you how to add or replace the RAM in your Toughbook CF-29.
Partes
No se requieren partes.
Locate the bay door for the battery on the left side of the laptop.
  • Locate the bay door for the battery on the left side of the laptop.
Agregar Comentario
Slide the latch to the right and then down to unlock it. Pull out the battery.
  • Slide the latch to the right and then down to unlock it.
  • Pull out the battery.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Agregar Comentario
Pull the clips aside to release and remove the RAM.
  • Pull the clips aside to release and remove the RAM.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 27-93, Amido Spring 2010 Miembro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Miembros
12 Guías creadas
Thanks for sharing this. I just bought a panasonic toughbook from http://buytough.com and I think this will come in handy. :)
Katie Sutton - Contestar
there is another ram slot you failed to mention
sparkynaz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 7
Todo El Tiempo: 17,537
