Introducción
This guide provides the steps to remove the back cover. This process is necessary to access many of the components inside.
Locate the bay door for the battery on the left side of the laptop.
  • Locate the bay door for the battery on the left side of the laptop.
Agregar Comentario
Slide the latch to the right and then down to unlock it. Pull out the battery.
  • Slide the latch to the right and then down to unlock it.
  • Pull out the battery.
Agregar Comentario
Flip the device upside down with the handle facing away from you.
  • Flip the device upside down with the handle facing away from you.
  • Open the optical drive bay by sliding its latch to the right.
  • Locate optical drive release mechanism on the bottom of the laptop.
Agregar Comentario
Slide the latch cover to the right.
  • Slide the latch cover to the right.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Push the exposed switch to the left to eject the optical drive. Push the exposed switch to the left to eject the optical drive.
  • Push the exposed switch to the left to eject the optical drive.
Agregar Comentario
Begin by turning the laptop upside down with the handle towards you.
  • Begin by turning the laptop upside down with the handle towards you.
  • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Agregar Comentario
Remove the panel and set it aside.
  • Remove the panel and set it aside.
  • Use a Phillips size 0 screwdriver to remove these 8 small screws.
Agregar Comentario
Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
Agregar Comentario
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive. Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Agregar Comentario
Be careful when lifting the cover as you may damage some connections.
  • Be careful when lifting the cover as you may damage some connections.
  • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Agregar Comentario
Now the back cover should be off and you can access the inside of the casing.
  • Now the back cover should be off and you can access the inside of the casing.
Agregar Comentario
Conclusión
Rohun Heesen
Miembro Desde 13/04/10
330 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 27-93, Amido Spring 2010 Miembro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 27
Todo El Tiempo: 8,878
