Partes
No se requieren partes.
With the front display of the device facing you, rotate the device 90 degrees counter clockwise. Now rotate the device 180 degrees and remove the second screw. Remove the screw that is on the right side of the panel facing you.
  • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
  • Now rotate the device 180 degrees and remove the second screw.
  • Remove the screw that is on the right side of the panel facing you.
    • All screws will need to be removed with a phillips head screwdriver.
Agregar Comentario
Rotate the device so that the back faces you. With a phillips heat screwdriver, locate and remove the four screws highlighted by the red circles in image one.
  • Rotate the device so that the back faces you.
  • With a phillips heat screwdriver, locate and remove the four screws highlighted by the red circles in image one.
Agregar Comentario
Before removing cover make sure that the back of the device is facing you.
  • Before removing cover make sure that the back of the device is facing you.
  • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Pull up the two tabs on top Pull the the three tabs on the side there is one on the left and two and the right side of the device when it is facing you. Depress the four tabs on the bottom of the device.
  • Pull up the two tabs on top
  • Pull the the three tabs on the side there is one on the left and two and the right side of the device when it is facing you.
  • Depress the four tabs on the bottom of the device.
Agregar Comentario
Carefully pull off the front panel of the device.
  • Carefully pull off the front panel of the device.
  • The front is attached to the device with cables so be careful when removing.
Agregar Comentario
With the device front facing you remove the six screws with a phillips head screwdriver around the VHS drive. With the device front facing you remove the six screws with a phillips head screwdriver around the VHS drive.
  • With the device front facing you remove the six screws with a phillips head screwdriver around the VHS drive.
Agregar Comentario
Remove the three cables attaching the VHS to the Mother Board.
  • Remove the three cables attaching the VHS to the Mother Board.
  • Carefully pull the VHS drive out of the device and follow the steps in reverse to place the new one in.
Agregar Comentario
Conclusión
Nathan Cheadle
Miembro Desde 15/04/10
137 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 16-5, Maness Spring 2010 Miembro de Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 810
