Introducción
Remove all necessary parts of the camcorder in order to gain access to remove and replace a bad logic board.
Partes
No se requieren partes.
Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder. Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder. Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
  • Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
Agregar Comentario
Open the tape compartment. Using a #00 Phillips head screwdriver, remove the two 4.5mm screws from the camcorder.
  • Open the tape compartment.
  • Using a #00 Phillips head screwdriver, remove the two 4.5mm screws from the camcorder.
Agregar Comentario
Use a plastic opening tool to remove the gray trim piece from top of the camcorder. Take care when removing the trim piece. The plastic parts are fragile and can break easily. Take care when removing the trim piece. The plastic parts are fragile and can break easily.
  • Use a plastic opening tool to remove the gray trim piece from top of the camcorder.
  • Take care when removing the trim piece. The plastic parts are fragile and can break easily.
Agregar Comentario
Rotate the camcorder so that the eye piece is facing you, and remove the battery. Remove the four black 4.5mm screws, which sit behind the battery. Then, remove the 5th screw to the right of the battery dock.
  • Rotate the camcorder so that the eye piece is facing you, and remove the battery. Remove the four black 4.5mm screws, which sit behind the battery. Then, remove the 5th screw to the right of the battery dock.
  • Be careful not to lose any screws whilst trying to remove them.
Agregar Comentario
Rotate the camcorder so that the tape compartment is facing you. Remove the single 4.5mm black screw, which is above the hook for the hand strap. It may help you during this step to undo the strap on one end.
  • Rotate the camcorder so that the tape compartment is facing you. Remove the single 4.5mm black screw, which is above the hook for the hand strap.
  • It may help you during this step to undo the strap on one end.
  • Next, rotate the camcorder so that the lens is facing you. Remove the single 4.5mm black screw from the front panel.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Rotate the camcorder so that the bottom is facing towards you. Remove the single remaining 4.5mm black screw from the bottom. Next, while still having the bottom of the camcorder facing you, remove the four silver 4.5mm screws from the body.
  • Rotate the camcorder so that the bottom is facing towards you. Remove the single remaining 4.5mm black screw from the bottom.
  • Next, while still having the bottom of the camcorder facing you, remove the four silver 4.5mm screws from the body.
Agregar Comentario
Open the LCD screen on the side of the camcorder.
  • Open the LCD screen on the side of the camcorder.
  • Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
Agregar Comentario
Very carefully remove the front cover from the main body of the camcorder. This should come apart with relative ease, however a plastic opening tool may help you remove this panel a little more easily.
  • Very carefully remove the front cover from the main body of the camcorder.
  • This should come apart with relative ease, however a plastic opening tool may help you remove this panel a little more easily.
  • There is a ribbon cable attached to the front panel and the camcorder body, so be careful not to pull that off when you remove this panel.
Agregar Comentario
Using your fingers, carefully pull the ribbon cable away from the logic board. Using your fingers, carefully pull the ribbon cable away from the logic board.
  • Using your fingers, carefully pull the ribbon cable away from the logic board.
Agregar Comentario
Now, from where the front cover used to be, remove the two 4.5mm black screws from the LCD side of the camera. Now, from where the front cover used to be, remove the two 4.5mm black screws from the LCD side of the camera.
  • Now, from where the front cover used to be, remove the two 4.5mm black screws from the LCD side of the camera.
Agregar Comentario
Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.  Using two tools may be useful, if difficult. Move the plastic opening tool up the side of the camcorder as shown, carefully separating the LCD panel from the rest of the camcorder. With the blue LCD panel free from the rest of the camcorder, remove the panel from the camcorder.
  • Place a plastic opening tool under the bottom of the blue panel beneath the camcorder. Using two tools may be useful, if difficult.
  • Move the plastic opening tool up the side of the camcorder as shown, carefully separating the LCD panel from the rest of the camcorder.
  • With the blue LCD panel free from the rest of the camcorder, remove the panel from the camcorder.
Agregar Comentario
Before you fully remove the LCD panel from the camcorder, be sure to remove the ribbon cables that connect the LCD panel to the logic board. There may be multiple ribbon cables attached to the same point on the logic board. There may be multiple ribbon cables attached to the same point on the logic board.
  • Before you fully remove the LCD panel from the camcorder, be sure to remove the ribbon cables that connect the LCD panel to the logic board.
  • There may be multiple ribbon cables attached to the same point on the logic board.
Agregar Comentario
Using the spudger, remove the few remaining ribbon cables from the logic board. Using the spudger, remove the few remaining ribbon cables from the logic board. Using the spudger, remove the few remaining ribbon cables from the logic board.
  • Using the spudger, remove the few remaining ribbon cables from the logic board.
Agregar Comentario
To remove the logic board from the body, use the #00 phillips head screwdriver and remove the 4mm silver screw from right side of the board. Next, rotate the camcorder so the front is facing you and remove the 4mm silver screw from the front panel. Carefully lift the logic board away from the camcorder.
  • To remove the logic board from the body, use the #00 phillips head screwdriver and remove the 4mm silver screw from right side of the board.
  • Next, rotate the camcorder so the front is facing you and remove the 4mm silver screw from the front panel.
  • Carefully lift the logic board away from the camcorder.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Tommy
Miembro Desde 18/04/10
97 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-9, Maness Spring 2010 Miembro de Cal Poly, Team 7-9, Maness Spring 2010
CPSU-MANESS-S10S7G9
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 2,478
