Partes
No se requieren partes.
Remove the battery and memory card from the device.
  • Remove the battery and memory card from the device.
Agregar Comentario
Remove 4 screws from the right side of the camera.
  • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
Agregar Comentario
Remove the single 3.4mm screw on the left side of the camera.
  • Remove the single 3.4mm screw on the left side of the camera.
Agregar Comentario
Remove 5 screws from the base of the camera.
  • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
Agregar Comentario
Slowly slide the back cover away from the device
  • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
Agregar Comentario
Detach both ribbon cables using a spudger. Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
Agregar Comentario
Remove the back casing from the camera.
  • Remove the back casing from the camera.
Agregar Comentario
Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip. Carefully remove the function switch cover. This unit snaps on and off.
  • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
  • Carefully remove the function switch cover. This unit snaps on and off.
Agregar Comentario
Carefully unsnap the front logic board from the rear logic board using a spudger.
  • Carefully unsnap the front logic board from the rear logic board using a spudger.
Agregar Comentario
Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera. Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
  • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
Agregar Comentario
Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger. This leaves you with the logic board and the top connection panel separate and free from the camera This leaves you with the logic board and the top connection panel separate and free from the camera
  • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
  • This leaves you with the logic board and the top connection panel separate and free from the camera
Agregar Comentario
Conclusión
Ben Canfield
Miembro Desde 10/10/10
391 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 9-21, Regan Fall 2010 Miembro de Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 11
Todo El Tiempo: 4,978
