Introducción
The front casing is the frontal frame on your Panasonic Lumix DMC-TZ5. All the major components of the camera are attached to this front casing.
Partes
No se requieren partes.
Remove the battery and memory card from the device.
  • Remove the battery and memory card from the device.
Agregar Comentario
Remove 4 screws from the right side of the camera.
  • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
Agregar Comentario
Remove the single 3.4mm screw on the left side of the camera.
  • Remove the single 3.4mm screw on the left side of the camera.
Agregar Comentario
Remove 5 screws from the base of the camera.
  • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
Agregar Comentario
Slowly slide the back cover away from the device
  • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
Agregar Comentario
Detach both ribbon cables using a spudger. Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
Agregar Comentario
Remove the back casing from the camera.
  • Remove the back casing from the camera.
Agregar Comentario
Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip. Carefully remove the function switch cover. This unit snaps on and off.
  • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
  • Carefully remove the function switch cover. This unit snaps on and off.
Agregar Comentario
Carefully unsnap the front logic board from the rear logic board using a spudger.
  • Carefully unsnap the front logic board from the rear logic board using a spudger.
Agregar Comentario
Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera. Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
  • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
Agregar Comentario
Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger. This leaves you with the logic board and the top connection panel separate and free from the camera This leaves you with the logic board and the top connection panel separate and free from the camera
  • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
  • This leaves you with the logic board and the top connection panel separate and free from the camera
Agregar Comentario
Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
  • Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
Agregar Comentario
Remove the 3 screws holding the lens assembly in place.
  • Remove the 3 screws holding the lens assembly in place.
    • The two screws on the left are 4.5mm with washers.
    • The single screw on the right is 4mm.
Agregar Comentario
Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
  • Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
Agregar Comentario
Remove the entire assembly out of the casing. The ribbons on the left and bottom of the assembly simply rest on the camera housing.
  • Remove the entire assembly out of the casing.
    • The ribbons on the left and bottom of the assembly simply rest on the camera housing.
Agregar Comentario
Use the spudger to unclip the top ribbon cable from the circuit board.
  • Use the spudger to unclip the top ribbon cable from the circuit board.
Agregar Comentario
Remove the single 2mm screw in the bottom right corner of the circuit board
  • Remove the single 2mm screw in the bottom right corner of the circuit board
Agregar Comentario
Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove. The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
  • Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove.
    • The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
Agregar Comentario
Take note of how the slots fit into the circuit board for easy replacement.
  • Take note of how the slots fit into the circuit board for easy replacement.
Agregar Comentario
After removing the AV circuit board you are left with the front casing attached to the inner casing and flash unit.
  • After removing the AV circuit board you are left with the front casing attached to the inner casing and flash unit.
  • First you must remove two 3.5mm blue screws near the hole of the lens that attach the inner casing.
Agregar Comentario
Remove the 3.5mm colorless screw that lays within the square opening of the inner casing.
  • Remove the 3.5mm colorless screw that lays within the square opening of the inner casing.
Agregar Comentario
Remove the front casing from the rest of the device.
  • Remove the front casing from the rest of the device.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Kevin Lufkin
Miembro Desde 11/10/10
158 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-21, Regan Fall 2010 Miembro de Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 10
Todo El Tiempo: 7,100
