Introducción
The guide will take you through the steps of how to remove the memory card.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
Move the switch on the battery door to the Open position.
  • Move the switch on the battery door to the Open position.
  • The door will automatically swing open after you let it go.
Agregar Comentario
Push the small gray tab on the top right corner to the left. The battery will pop out slightly. Keep your finger clear of the battery when it pops out.
  • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
  • Keep your finger clear of the battery when it pops out.
Agregar Comentario
Push the memory card in and let go.
  • Push the memory card in and let go.
  • The memory card will pop out slightly.
  • Pull out the memory card.
Agregar Comentario
Conclusión
Karissa
Miembro Desde 13/04/12
50 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 6-23, Amido Spring 2012 Miembro de Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 6
Todo El Tiempo: 587
