Introducción
The LCD screen is one of the most vital components of the camera. It conveniently shows you the pictures you have taken with your camera and displays the options and settings for your camera.
Partes
No se requieren partes.
Move the switch on the battery door to the Open position.
  • Move the switch on the battery door to the Open position.
  • The door will automatically swing open after you let it go.
Agregar Comentario
Push the small gray tab on the top right corner to the left. The battery will pop out slightly. Keep your finger clear of the battery when it pops out.
  • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
  • Keep your finger clear of the battery when it pops out.
Agregar Comentario
Push the memory card in and let go.
  • Push the memory card in and let go.
  • The memory card will pop out slightly.
  • Pull out the memory card.
Agregar Comentario
Unscrew the small screws on the sides of the camera. The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  • Unscrew the small screws on the sides of the camera.
  • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
Agregar Comentario
Unscrew the three small screws on the bottom(#00P, 3.3mm). The bottom will fall off.
  • Unscrew the three small screws on the bottom(#00P, 3.3mm).
  • The bottom will fall off.
Agregar Comentario
Lift up the bottom back cover by prying the bottom edge with the spudger. Gently lift up the back cover with your hand from the bottom to the top. Gently lift up the back cover with your hand from the bottom to the top.
  • Lift up the bottom back cover by prying the bottom edge with the spudger.
  • Gently lift up the back cover with your hand from the bottom to the top.
Agregar Comentario
Lift the tabs on the ZIF connectors. The ribbon cables should easily come out of the ZIF connectors. The ribbon cables should easily come out of the ZIF connectors.
  • Lift the tabs on the ZIF connectors.
  • The ribbon cables should easily come out of the ZIF connectors.
Agregar Comentario
Use the pointed end of the spudger to pry off the LCD screen from the back cover. Place the tip of the spudger in the small hole in the bracket on the LCD screen and lift it out. Use the pointed end of the spudger to pry off the LCD screen from the back cover. Place the tip of the spudger in the small hole in the bracket on the LCD screen and lift it out. Use the pointed end of the spudger to pry off the LCD screen from the back cover. Place the tip of the spudger in the small hole in the bracket on the LCD screen and lift it out.
  • Use the pointed end of the spudger to pry off the LCD screen from the back cover. Place the tip of the spudger in the small hole in the bracket on the LCD screen and lift it out.
Agregar Comentario
Conclusión
James Cruz
Miembro Desde 14/04/12
6 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 6-23, Amido Spring 2012 Miembro de Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 1,361
