Introducción
Directions are given as if you were holding the camera to take a picture.
Partes
No se requieren partes.
Locate the memory card and battery card latch on the bottom of the camera.
  • Locate the memory card and battery card latch on the bottom of the camera.
  • Slide the latch to the open position.
Agregar Comentario
Open the battery latch, and slide the battery release lever to the right.
  • Open the battery latch, and slide the battery release lever to the right.
Agregar Comentario
Remove the battery from the camera.
  • Remove the battery from the camera.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
  • Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
  • Use this screwdriver for all screws in the device.
Agregar Comentario
Remove the 3.15 mm screw on the left side of the camera.
  • Remove the 3.15 mm screw on the left side of the camera.
Agregar Comentario
Remove the left side casing. Remove the left side casing.
  • Remove the left side casing.
Agregar Comentario
Remove the two 3.15 mm screws on the right side of the camera.
  • Remove the two 3.15 mm screws on the right side of the camera.
Agregar Comentario
Remove the bottom right panel.
  • Remove the bottom right panel.
Agregar Comentario
Gently remove the back casing. Start at the bottom and carefully pry towards the top to get this piece free.
  • Gently remove the back casing.
  • Start at the bottom and carefully pry towards the top to get this piece free.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Andrew
Miembro Desde 11/10/10
381 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-22, Regan Fall 2010 Miembro de Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 4
Todo El Tiempo: 3,038
