Introducción
Fixing the lens apparatus on your camera.
Partes
No se requieren partes.
Slide the lock into the unlock position.In this case you would need to slide the lock to the right.
  • Slide the lock into the unlock position.In this case you would need to slide the lock to the right.
  • Use your finger to slide battery hatch towards the arrow sign.
  • Both battery and memory card should now be visible.
Agregar Comentario
Open battery hatch and the black cover to expose the battery compartment.
  • Open battery hatch and the black cover to expose the battery compartment.
  • The camera used to create these repair guides did not have a battery and memory card.
  • Pull the battery out and replace with a new one.
  • When putting the battery back in, make sure it is in the same orientation as before.
  • Close the battery compartment and make sure the lock is in the locked position.
Agregar Comentario
Remove the two 2.8 mm Phillips screws as shown in picture.
  • Remove the two 2.8 mm Phillips screws as shown in picture.
Agregar Comentario
Using a Philips Screw Driver, remove the three 2.8 mm Phillips screws on the bottom of the camera as shown in picture.
  • Using a Philips Screw Driver, remove the three 2.8 mm Phillips screws on the bottom of the camera as shown in picture.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture. /state that a screwdriver is needed in the  step.
  • Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture. /state that a screwdriver is needed in the step.
Agregar Comentario
Use a Spudger tool to pry open case from all sides./No edits necessary Use a Spudger tool to pry open case from all sides./No edits necessary
  • Use a Spudger tool to pry open case from all sides./No edits necessary
Agregar Comentario
Beware of yellow film strip when opening./Caution: Beware of the yellow film strip when opening  the casing of the camera, make this caution notice a different color. Use your fingers to carefully pry off the back casing from the camera assembly/. No edits necessary.
  • Beware of yellow film strip when opening./Caution: Beware of the yellow film strip when opening the casing of the camera, make this caution notice a different color.
  • Use your fingers to carefully pry off the back casing from the camera assembly/. No edits necessary.
Agregar Comentario
Lay the camera on its front side./combine this sentence to the step below.
  • Lay the camera on its front side./combine this sentence to the step below.
  • Use Spudger tool to open the film strip locking mechanism and remove strip./No edits necessary.
  • Hold down on the camera's metal casing with one hand. Using your other hand, completely lift the back case off the rest of the camera, making sure the film strip separates./Make a picture for this step.
Agregar Comentario
Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
  • Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
  • The other three screws shown in picture were removed to take off the back case.
Agregar Comentario
Using Spudger tool, pry the front case from the camera's components. Use your fingers to carefully pull the back case from the front case. Cut the black and red wires connecting front case to the body of the camera.
  • Using Spudger tool, pry the front case from the camera's components.
  • Use your fingers to carefully pull the back case from the front case.
  • Cut the black and red wires connecting front case to the body of the camera.
  • Being careful nothing get's caught, separate the front case from the camera.
  • To put the new front case back on, solder the wires of the new front case to the components of the camera.
Agregar Comentario
Check the "V" shaped spring to see if it is connected at shown location.
  • Check the "V" shaped spring to see if it is connected at shown location.
Agregar Comentario
Manually move the Lens Apparatus from the inside to shown position.
  • Manually move the Lens Apparatus from the inside to shown position.
  • Check to see if the spring is aligned correctly and lens opens.
  • If not, you will need to take out the spring and place it into the proper position, or get a new spring all together.
  • To reassemble your device, follow these instructions in reverse order.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Alex Penman
Miembro Desde 28/01/11
480 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-35, Regan Winter 2011 Miembro de Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,164
