Partes
No se requieren partes.
Eject the disk tray from the DVD player before removing power supply.
  • Eject the disk tray from the DVD player before removing power supply.
Agregar Comentario
Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier dissasembly of the player.
  • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier dissasembly of the player.
Agregar Comentario
Remove 3 screws running along back edge of case cover. Remove 2 screws from each side of case cover.
  • Remove 3 screws running along back edge of case cover.
  • Remove 2 screws from each side of case cover.
Agregar Comentario
Grab edges of cover, pull outward slightly, and pull straight up.
  • Grab edges of cover, pull outward slightly, and pull straight up.
Agregar Comentario
Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player. Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
  • Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
Agregar Comentario
Conclusión
Kevin
Miembro Desde 26/04/11
351 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 18-20, Garner Spring 2011 Miembro de Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 2,197
