Saltar al contenido principal
Panasonic D-snap SV-AV50 Screen Replacement
Qué necesitas
  1. Panasonic D-snap SV-AV50 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
    • Then, rotate the screen 180 degrees and remove the screw on the opposite side.
  2. Panasonic D-snap SV-AV50 Screen Replacement: paso 2, imagen 1 de 1
    • Remove the screw(2.6mm Philips) indicated on the top of the screen with the screwdriver. Then remove the corresponding screw on the bottom of the screen.
  3. Panasonic D-snap SV-AV50 Screen Replacement: paso 3, imagen 1 de 1
    • Pull the backing away from the screen as shown in the photo.
  4. Panasonic D-snap SV-AV50 Screen Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Unplug the black connector between the camera and the screen by pulling down.
    • For increased ease, use tweezers or forceps, as seen in the picture
  5. Panasonic D-snap SV-AV50 Screen Replacement: paso 5, imagen 1 de 1
    • Pull the screen away from the camera the same way that you removed the screen backing.
  6. Panasonic D-snap SV-AV50 Screen Replacement: paso 6, imagen 1 de 1
    • Use the screwdriver to remove the screw(2.46mm Philips) indicated.
  7. Panasonic D-snap SV-AV50 Screen Replacement: paso 7, imagen 1 de 1
    • Pull upwards on the screen border to remove it from the actual screen.
Conclusión
Zoe Hinck
Miembro Desde 04/12/12
29 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-19, Amido Spring 2012 Miembro de Cal Poly, Team 6-19, Amido Spring 2012
CPSU-AMIDO-S12S6G19
3 Miembros
12 Guías creadas
Un comentario
I need the LCD screen, can you helpme?
leon - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 1,077
